RCU Forums - View Single Post - Hitec servos
Thread: Hitec servos
Old 03-15-2004 | 12:14 AM
dbow's Avatar
dbow
Default RE: Hitec servos
ORIGINAL: neap38
hmmm today i swapped my servo in my on road car with the servo from my buggy (hitec servo) and now none of my servos are working :-s I checked all the conections e.t.c and still nothing .
You need to check polarity on the servos, if your electronics are different in the car (different connectors) then you may have the Hitec backwards.
ORIGINAL: neap38
Can you run two different makes of servos in your car?? I heard if there different voltages then it wont work. Is this right?
Most common servos are rated for both 4.8volts and 6volts so you should not have any problems with mixing servos. I do it all the time, I have Hitecs and futabas mixed in my planes and cars. As long as you hook em up right you should see no problems.
In some cases High torque servos will exhibit problems with low voltages or with alkalines, they however should still operate but may not operate at optimum performance. For high torque servos always run 6 volts.
For more detailed information run a search on the radio forum and ask your question directly to manuf. support here on RCuniverse.
Goodluck
Dbow
