RCU Forums - View Single Post - World Models p51
Old 03-15-2004 | 03:15 PM
MerlinL14
Default RE: World Models p51
More mods added!! I found that the ASP did not like to idle at anything under 3200rpm Inverted, it ran at 2100rpm upright for the break in. So I have added an onboard glow system. I searched the forum to see what ppl thought of them, and which one to get, turns out they are too expensive and too heavy. I ended up making my own for the princely sum of £4.10. I just used a 'master arm switch' a micro switch and a battery from a glow starter, a bit of wireing and some heatshrink and fuel hose on the throttle arm to activate the micro switch and bingo it works from idle to 1/4 throttle. I have left the remote glow (wired into the same circuit) as a 'boost' if I need it for starting and as a charge socket for the onboard battery.
