What size spinner to use with APC 12x6 prop?
You will find that most spinner will not work right out of the package with APC props. You will need to take your dremel and a sanding drumb and modify the prop opening to accomodate your propeller. If you don't have a dremel, you can use a file to do the same thing but it will take some time.
