Hi tIANci
What i ment to say is that at full throttle itll go where i point it, not dragging its tail..
14oz added to the nose sounds like a hell of alot of extra weight to add.I didnt need to add any to mine as it was spot on but im going to try it a bit farther faward for the next flight,doyou think going to 95mm from LE is going to be ok?
I think this plane would be better with say the ringed 50 in it, like you say its not realy a record braker in a straight line..
Id like to know the weight of it as well so ill have to weight it later when i work on it. You dont know the weight of your friends plane by any chance?
