RCU Forums - View Single Post - Wattage live wire
Old 03-16-2004 | 07:10 AM
rc flyer uk
Default RE: Wattage live wire
It should do you fine for a bit of fun but as you said not serious 3D!! You want to open the gear up and make sure all the teeth are inline!! On mine wernt and after the first flight it stripped the gears! I replaced it with a GWS 350D! You will also want to make sure that the CG is in the right place as with the lack of power if its to far back it gets a bit hairy, especially when you have to turn quick to avoid the trees in small fields !!
If you want any more info just ask!
oh and be careful with those litle plastic hinges on ruder!! and use good tape on the ailerons!!
Rob
