by Stephen Bess (sb22) on Mon Mar 15 22:23:35 2004:
Researching the VZ-B V-Spec a little...
Found out that the carb is supposedly back to a 2-needle carb w/two
inserts (8mm and 9mm), turbo plug head, same bore & stroke as VZ-B,
billet piston. No idea about the p/s composition or if it has been
changed.
Also, it says for sale May 2004 so I'm guessing that means sale in
Japan. We probably won't get 'em in the US 'till the fall if that's
true.
Looks like this one too has the billet piston.
I figured that would be the case after reading OS is going to can the cast pistons entirely.
On the bright side it looks cool...
