Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC 1/8th Scale Buggies
 New OS Max Buggy engine - Possible VZ replacement? >
RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Old 03-16-2004 | 02:46 PM
Nitroaddict's Avatar
Default New OS Max Buggy engine - Possible VZ replacement?
O.S. Engines has announced a second generation .21 VZ-B V-Spec engine for competition buggy racing. Presumably following in the footsteps of the VZ-R, the new VZ-B is sure to include technology that will further enhance performance. Information is scarce at the moment, but I sure hope they resolved the piston problem.
Old 03-16-2004 | 03:02 PM
RobH's Avatar
Default RE: New OS Max Buggy engine - Possible VZ replacement?
by Stephen Bess (sb22) on Mon Mar 15 22:23:35 2004:
Researching the VZ-B V-Spec a little...
Found out that the carb is supposedly back to a 2-needle carb w/two
inserts (8mm and 9mm), turbo plug head, same bore & stroke as VZ-B,
billet piston. No idea about the p/s composition or if it has been
changed.
Also, it says for sale May 2004 so I'm guessing that means sale in
Japan. We probably won't get 'em in the US 'till the fall if that's
true.
Looks like this one too has the billet piston. I figured that would be the case after reading OS is going to can the cast pistons entirely.
On the bright side it looks cool...
Old 03-16-2004 | 03:36 PM
theShark's Avatar
obscure looking head....those fins are going to break off even easier now, probably trying to get the air to flow down and over the glow plug.
