RE: Walbro WT 433 Question
Jerry, the carbs have a stiffer plastic type of pump rather that the rubber one. I took the pump plate off and primed the carbs innards and put it back together and it took right off. I guess these carbs were used on a motor that had a primer bulb or something that made it easier to start the first time. Anyway, once i got the motor running on the carb its ran fine ever since.
