RCU Forums - View Single Post - hinge question on my trainer
Old 03-17-2004 | 07:41 PM
phread59
Default RE: hinge question on my trainer
Those hinges should work just fine. The only suggestion I would give is to pin them. What I mean is after the hinges are glued in. You drill a hole in each half through the moveable surface and the mount. Then glue a hardwood dowel, toothpick or whatever you can find. This is just a safty thing, just in case. Good luck.
Mark Shuman
