RCU Forums - View Single Post - Its Here!! Double Vision
Old 03-17-2004 | 09:14 PM
  #59
rgreen24's Avatar
rgreen24
Default RE: RE: Its Here!! Double Vision
Hey Kitman I got my double V today and you were right--- what an awesome looking plane. It has the biggest rudder I have ever seen on a plane. Say I wanted to ask you about how you go about setting up your ailerons. This is my first bipe and I -- I know how to Y off each side but I don't know how to hook th servo up to the Y harness and then to receiver. Do you have any pics of how you did it. I am just wondering if the Y harness meets the extensions inside the plane or by the Cabane. Your help would be much appreciated. By the way are you going to tap your wing tube? I am planning on putting hard wood dowels into each section of the wing tube, so the screw has something more to bite into more than just a tap. I do not trust the tap set up. I know that it may have work for people in the past and present, but I like to feel a little more secure knowing that the screw it boltled into the wood and there is no chance of it coming out.
