RE: Husqvarna 45cc conversion
Exactly the same and I have Professional stamped also on it. I have to take the engine mount to work so a friend can drill a bigger hole for the shaft since I only had 10mm drill at home. I'm going to use an old runtronic system that should do the job for me since it has auto advance of what you can it built in.
I don't know what plane to put it in since the thing I want to do is to get this thing running and then decide what plane to build. I have a drawing of the Shukoi MX-26 that is for a .91 four-storke and I was thinking of enlarge it a little bit.
