RE: Suggestions needed with SHRIKE fueling setup
if you try to fill up with the muffler line it will spit out the carb line. There is no where for the pressure to relive to. I would add another line to my fuel tank and have that fuel line come out somewhere easy to grab. Then you can fill up the same as if you was pulling line of carb. And since you will have your line to muffler still it will vent from there.
