RE: Its Here!! Double Vision
Mark Novak, The hardware pack is very complete, they supply ball bearing aluminum control horns and clevises for all surfaces, very smooth. The cabane struts are preformed fiberglass that simply slip over the screwed in hold down, great design!
The center pipe section is a very light fiberglass tray that the pipe to sits in, David at Desert Aircraft is sending a header kit for me help with the design, we are using the KS wide canister, because he believes it has better performance specs with his DA-50, more to come as I get the design worked out.
Kitman
