RE: How important is balancing plastic spinner backplate?
On the Avistar with an OS 46 forget the spinner and what possessed you to want to put an 11x4 prop on it? I run a GMS 47 on a strickly 3D bird with an 11x4 prop cause it needs the thrust. Are you planning on trying to hover the Avistar?
Good luck,
