RCU Forums - View Single Post - Hyde mount for a Saito
Old 03-19-2004 | 09:40 AM
TOYMAKER
Default RE: Hyde mount for a Saito
If I remember correctly there is no room or smooth surface on the front of the crank on a Saito for a nose ring.
You will probably have to get his mount version that does not require a nose ring. It is larger and heavier then the std mount.
Raptor...
Do not cut the mount for the clearance you will ruin the mount. If you want I could make you one like mine. Email me off line.
Wayne
