ORIGINAL: wojtek
There is a new manufacturer that will soon (within the month) be releasing a whole new line of bubble free tanks which are BETTER than BVMs and significantly cheaper, and that use an even more efficient pickup bag system ... no more paying $60 for a header ! on top of that, the tanks will come with ALL festo fittings (either compression fittings or quick release). Economy versions will also be available for even less, which will feature standard barbed nipples for fill, and up-rank , and still have a compression fitting on the top (to pump) .. On top of all this various tank sizes will be available.
Besides the header tanks there will be overflow tanks of various sizes, fest conversion kits for primary fuel tanks, as well as several other jet/turbine oriented products .... all at SIGNIFICANTLY lower prices than anything out there now !!
Wojtek
Hi Wojtek,
Who is doing it? Any more details?
BTW you are allowed to answer even if you are the one doing it, as I asked! I know these things!
