RE: Suggestions needed with SHRIKE fueling setup
Because you cant remove the fuel like that. It is like trying to use pressure line to remove fuel. There is no pick up on bottom of tank then.
But if you run the fuel out completely on each flight or don't remove fuel when done that will work out okay. I usually don't run the fuel out on my Shrike always try to leave reserve. But everyone flies different so it is really a preference on each person.
