RE: Poulan 46 Replacement Carb
The reason I wanted a replacement carb is because the the engine wouldn't stay running on the original (new) carb. I just found out that I re-assembled the throttle plate incorrectly! I had set the plate to open from the idle port towards the engine. This of course leaves no transition from idle port 1 to 2 and then 3. I realized this as I was tossing it into the trash can! After correcting my mistake, the engine now starts and runs great. I just can't get the idle down. Question - does the small notch in the throttle plate line up with the idle ports or does it go 180 degress away from the idle ports? I currently have the small notch over the idle ports. The plate is as closed as it can be and the idle is still very high. Any suggestions would be appreciated.
Thanks everyone.
GP Wagstaff
Futaba 9C
Hitec HS 645s x4, Futaba S3305s x2, 2 small servo's for throttle and choke
New Poulan 46cc demo carcass from Home Depot - $30!
CH ignition w/Bosch cap
