Poulan 46 Replacement Carb
Old 03-19-2004 | 01:17 PM
My Feedback: (20)
Default Poulan 46 Replacement Carb
Does anyone have suggestions on a good replacement carb for the Poulan 46cc?
Old 03-19-2004 | 04:47 PM
Default RE: Poulan 46 Replacement Carb
The stock carbs will work fine on this motor. Most seem to come with a Walbro WT610
I've changed mine to a WT 529. The 529 has a more freindly choke setup
Old 03-19-2004 | 06:41 PM
Wacker Engines sells new carbs for $20, but I am not sure which Walboro model they are.
Old 03-19-2004 | 07:40 PM
My Feedback: (20)
Thanks for the info. Thanks I will check out the 529.
Old 03-19-2004 | 08:41 PM
Antique's Avatar
WT 529, retail $34+, dealer cost is less than half..
Venturi size 13.49mm, about 1/2 inch....
Old 03-21-2004 | 05:07 PM
My Feedback: (20)
The reason I wanted a replacement carb is because the the engine wouldn't stay running on the original (new) carb. I just found out that I re-assembled the throttle plate incorrectly! I had set the plate to open from the idle port towards the engine. This of course leaves no transition from idle port 1 to 2 and then 3. I realized this as I was tossing it into the trash can! After correcting my mistake, the engine now starts and runs great. I just can't get the idle down. Question - does the small notch in the throttle plate line up with the idle ports or does it go 180 degress away from the idle ports? I currently have the small notch over the idle ports. The plate is as closed as it can be and the idle is still very high. Any suggestions would be appreciated.
Thanks everyone.
GP Wagstaff
Futaba 9C
Hitec HS 645s x4, Futaba S3305s x2, 2 small servo's for throttle and choke
New Poulan 46cc demo carcass from Home Depot - $30!
CH ignition w/Bosch cap
Old 03-21-2004 | 10:33 PM
My Feedback: (26)
ORIGINAL: vxoa203
Thanks everyone.
GP Wagstaff
Futaba 9C
Check for an air leak, may be a bad gasket under carb or warped carb mounting block, crankcase halves, etc.
Old 03-21-2004 | 11:35 PM
Antique's Avatar
There's a bevel on the edges of the plate so it can close completely.....
Old 03-26-2004 | 11:14 PM
My Feedback: (22)
Mine had a WT-657. I could not find it on Walbro's site. I wonder if this means I have a very old P-46, or a very new one? It seemed to work fine when I test cranked the chainsaw.
Old 03-26-2004 | 11:53 PM
Antique's Avatar
The latest batch of environmentally friendly carbs are not in the book yet..Yours is one of these..
Old 03-27-2004 | 12:46 AM
My Feedback: (22)
Thank you RCIGN1. Interesting....a tree hugging carb on a chainsaw!
