RCU Forums - View Single Post - Hello, Need some help
Old 03-21-2004 | 07:06 PM
Ashes
Default RE: Hello, Need some help
Thanks for the response. The damage is not that bad really. One corner of the block broke off as the drill bit got about halfway through. I have used 30 minute epoxy to glue it back on, as well as fill the damaged hole. I am in the process of strengthening the block with some ply also using epoxy. My only fear is that this weak spot in the landing block is going to cause me problems in the future. If it doesn't look up to the job after I am through I will just have to take it out and replace it. Being this is my first plane and problem with a plane how intensive of a job is it to remove a piece that has been epoxyed? Thanks again.
