RE: 4-Star
I had the problem of the tail wheel wire pulling out of the rudder assembly also. To fix it I fiberglassed a small loop around the wire and lower edge of the rudder. It has held up so far. Sig usually does a better design job than this. The other weak point is the fuse area that needs some reinforcement around hte wing saddle area.
