RE: Seagull Models <span class=
well my grand plan to replace the landing gear wont work, the fuse is 5 in wide and there isnt a gear that will replace it. What I did was take a piece of 1/4 square hardwood and screwed it in between the split in the two gears then I split the 1/4 hardwood in two and ca it behind the gears next to the front of the former that the wing dowels in to havent tested it yet but it does keep the gear from moving.
