RCU Forums - View Single Post - How to "fill" the gap between aileron and trailing edge?
Old 06-17-2002 | 03:00 AM
panzer66
Default How to "fill" the gap between aileron and trailing edge?
Hi,
I found the gaps between ailerons and the trailing edges of wings on my SIG Midstar are pretty wide (about 1.5-2mm). This is my first kit and I guess I didn't keep the gap tight enough.
Will this affect the integrity of the plane? Will the ailerons be teared off in the air? What remedies do I have to fix the gaps? Any kind of fillers available?
I used SIG easy hinges and there is no way I can remove them. All glued by CA thin.
Any help is appreciated.
