RCU Forums - View Single Post - How to "fill" the gap between aileron and trailing edge?
Old 06-17-2002 | 04:41 AM
TIGER2PLANE
Default How to "fill" the gap between aileron and trailing edge?
when I get a kit and build it I will not use CA hinges. I guess that I just keep them to long. I built one once with CA and about a year later the hinges broke and almost crashed. Now I use med dubro pinned hinges and epoxy or hinge glue. Never have had a problem since. I also cut out a notch on the working surface so they mount flush so you wont get any flutter when and if you have to much gap
