I recently hit a tree with my GP Shoestring and the ensuing damage cause the firewall to seperate from the fuse. The Mfg website says this plane has both right-thrust and down-thrust built in to the firewall. Note, I have glued it back on alreay and flown it successfully. However, is there an easy way I can go back and measure these angles to be assured I have the correct tolerances?
