RCU Forums - View Single Post - Do Prop savers really work?
Old 03-25-2004 | 03:57 PM
crewchief_432
Default RE: Do Prop savers really work?
Just take a standard size 2 sided servo arm and bolt it to the motor like it was the prop. take and cut the rest of the prop shaft off about a .25" from the nut. Then all you need to do is rubberband the prop to the servo arm.Hope this helps.....Jeremy
