Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
 Do Prop savers really work? >
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 03-24-2004 | 01:28 PM
3D  Flyer's Avatar
My Feedback: (37)
Default Do Prop savers really work?
I am considering putting a prop saver on my GWS 6.6:1 gear box with 12x6 slowflyer props on my 3DX. Do they really work? I am considering the wing nut idea with a #11 or 12 oring.
I am also considering turning off my ESC's brake ... does this help?
Old 03-24-2004 | 08:17 PM
Default RE: Do Prop savers really work?
I use a homemade prop saver made out of a standard size servo arm on all my planes that dont have a landing gear. I have yet to break a prop.
Old 03-25-2004 | 10:49 AM
IMO, yes. I've used several home made prop savers with success. However I wasn't using them to save the prop, I was using them to save the prop shaft on my GWS gearboxes.
Old 03-25-2004 | 01:08 PM
Ian.W's Avatar
can anyone tell me how to make one out of a standard futana fervos arm? tried to search on the ezone but it was abit croweded with rubbish
Old 03-25-2004 | 03:57 PM
Just take a standard size 2 sided servo arm and bolt it to the motor like it was the prop. take and cut the rest of the prop shaft off about a .25" from the nut. Then all you need to do is rubberband the prop to the servo arm.Hope this helps.....Jeremy
Old 03-25-2004 | 05:40 PM
Wow - Slick - I need to try that. As a newbie I've gone through a bunch of props.
Old 03-26-2004 | 12:45 AM
Levi_Jordan's Avatar
My Feedback: (21)
Guys.... send me $1.00 to cover shipping with paypal to [email protected] and I laser cut one of my prop savers for you and mail it back!
They work awesome, save the prop, propshaft, and they make prop swaps simple!
My Feedback: (21)
Foegot to say that they are laser cut from nylon, no wood...
Old 04-03-2004 | 01:19 PM
what a rip off!! they're not worth it, learn how to land![>:]
Old 04-06-2004 | 03:04 AM
patternflyer1's Avatar
They're not worth it is one statement. Another is that I haven't ever broke one prop since using them is another!!!!!!!![:'(] Never ruined another prop shaft since using them is another!!!!!!!!!!!1[:'(] I like to try lot's of stupid things real close to the ground. I'm never trying to land, it just happens sometimes when I'm doin stupid things. Anyone else agree with this and killed many prop shafts? Landing has little to do with it!!!!!!!!! And prop shafts get expensive and hard to come by when you do lots of fun, stupid things like I do............... YES, THEY DO WORK!!!!!!!!!!!!!!!!!!!!!!!
Old 04-10-2004 | 10:27 PM
how do you cut the shaft off?
Old 04-10-2004 | 10:31 PM
JohnVH's Avatar
My Feedback: (38)
Or as I do, get a wheel collar that fits the shaft, drill and tap another hole in the opposite side, use a couple screws to mount it to the shaft, then put a rubber band over the screws and the prop to hold it all together, works great.
Old 04-10-2004 | 11:50 PM
Cut the shaft with a dremel with a cut off wheel.
John, sounds like a good idea. I'm gonna have to weigh it though, lol.
Old 04-12-2004 | 10:15 PM
Hi, this system is almost what JhonVH meant. look [link=http://www.aircraft-world.com/shopexd.asp?id=2051]here[/link] and check if that would work, you also will need the special [link=http://www.aircraft-world.com/shopexd.asp?id=2052]shaft[/link].
Old 04-12-2004 | 11:36 PM
Hey 007. That shaft is aluminum though. That can't be very strong. I would probably go through a hundred of those. I don't think the aluminum could stand a chance versus the colibri shaft that is made from 17/4 heat treated stainless steel. http://www.e-flightline.com/gearboxes.htm. I could be wrong though. Just my 2 pennies worth.
