RCU Forums - View Single Post - GP Extra 300, 40 ARF expo settings
Old 06-18-2002 | 05:28 AM
KeithB's Avatar
KeithB
Default GP Extra 300, 40 ARF expo settings
Thanks ILikeplanes.
I flew it for the first time Monday. Flew pretty good but drifts to the left when coming over the top doing loops & Cuban eights. I'm working on adjustments now to try and straighten it out. First step was to adjust the right half of the elevator that had a slight warp in it making the two sides slightly uneven on the inner most portion of the elevator.
It's interesting to hear that you put right thrust in the plane, I may need to do the same. Were you seeing the same behavior of drifting left when going over the top of an inside loop? How much right thrust did you add?
You're right about the slow rolling. Also I had to add more elevator than is suggested in the manual. This probably indicates that I have the CG too far forward, I started at 4" as suggested in the manual.
Are you able to bring this plane in fairly slow without having it tip stall?
Thanks for the info, anything else that you can suggest would be appreciated.
Keith
