RE: Fun While it lasted!!!!!!!!!!
Thanks guys. I am using what I have on hand so I had to do a little re-aranging of the material. The fuse is 3/16 square, the spars are also 3/16 square balsa. I did not do as many diaginal truss brasings in the wing as I did last time. I also reused the ply nose from the first one. I am using up the scrap covering I have had for years so I had Purple and some of the original Gold berg Ultra coat, I made the pink out of the Utra coat.
I found out why my arrow was so heavy, I had forgotten I used a weight kit on the arrow to change the FOC. I took out the weight and it is a light weight again.
I still have to get the engine case, 2 servo gear sets, flexy prop to finish it. I do hope I get it under the 13 oz I need.
Dru.
