RE: mounting radio switch
Just a note. When using a switch mount (I do as often as possible), set it so that when you push the outside"Button" in you turn the radio ON. This will help with an inadvertant turn on. If you bump it the worst that happens is the radio batterys go dead. Better than a take off with the radio switched off.
Mark Shuman
