RCU Forums - View Single Post - Advice on engines
Old 03-28-2004 | 08:12 AM
Ian.W's Avatar
Ian.W
Default RE: Advice on engines
fogot to add, its got an integral ESC for the pump so you can set it up so at high power it makes lots of smoke and as you ruduce the throttle it gets less dence.
few more facts:
No flow regulator required - control and adjust smoke fluid flow from your transmitter!
Accurate flow control with our injector will give you a much cleaner burn - less residue on your plane!
The Mega smoke smoke-pump is an easy-to-fit electric geared pump designed to fit all types of engines from the small glow engines up to very large Gas Burners including gas turbines and helis.
This is a long life, high volume geared pump. It has electronics that not only starts and stops the unit, it also has volume control, so that you can adjust the amount of fuel that is pumped into your engine's exhaust.
This means that you can adjust the flow volume from your transmitter on the ground. No regulator valves, no back pressure on the fuel valve, and no leaks.
We also sell a special fluid injector to maximize the fuel burn. The key to a cleaner burn is to accurately control the fluid flow and disperse it with a quality injector. This will assure you of a maximum smoke, cleaner burn, less wasted fuel and much less mess!
Megasmoke Smoke-Pump Installation
The Megasmoke Smoke-pump is easy to fit. Simply install the unit anywhere in the aircraft, and ideally as far away from the receiver as possible.
Now for the easy part the transmitter set-up, Just plug the pump into a spare compact 6-9.6v battery which can be as small as possible, a 250mah 6v battery and just fast charge every 4-5 flights. The other spare lead coming out of the pump goes to a spare channel on your transmitter.
Pump Specifications Smoke Pump
Weight: 4 oz.
Size: 85mm x 35mm x 35mm
Voltage: 6v to 9.6v
Max Flow: 32oz in 15 min
Accurate Flow Control Gives You:
Less Wasted Smoke Fluid With transmitter adjustable flow control you can minimize wasted fluid. This will allow you to extend the length of time or capacity of your smoke tank!
Less Residue Because you have reduced the amount of excess fluid you will get a cleaner burn on your smoke. This cleaner burn will reduce the amount of residue that adheres to your plane!
