ORIGINAL: lax195
ORIGINAL: coolman01231
I have used 10 new glow plug batteries. Evader is brand new, When i pull the cord i can see the gears turn, the HSN is set at 2/1/4 for break in.
what do you mean you see the gears turn?? the gears arent supposed to turn when you are pulling the pull start. maybe your clutch is on too tight.
I second that! You shouldn't see the gear turn just by pulling the pull-start. Does the whole car want to roll when you yank on the pull-start?. Hold the rear of the car in the air and spin the rear wheel's. The spur and the clutch should spin freely if they don't then you need to pull the clutch bell off and check that the spring that holds the cluch shoes hasn't broken or come undone.
