RCU Forums - View Single Post - Gee Bee Arf 84"
Thread: Gee Bee Arf 84"
Old 06-20-2002 | 08:08 PM
B Shipp
My Feedback: (13)
Default Gee Bee Arf 84"
Fred,
A 8411 is overkill but if you have them use them. The new JR 811 would be a great servo to use on this airplane.
On the front of the box it read's " Like the original, our Gee Bee Y was not designed for very high speed or 3D aerobatic". I think it is a very well designed and built airframe, but if you put a G-62 on front of it , the wing center section would be your weak point. The manual shows the installation of a G-23, so any of the lower horsepower gas burners would be a good choice. The manual mentions something about gluing the wings together if using a larger motor. The only weak point in this kit is the manual. If you have built any ARF before you shouldn't have a problem, but if you have to follow the manual well.........It needs improvment.
The wheel pants should hold up like any other ARF. I build and fly UAV's for a living and do a lot of composite work. If I were to lay up the pants I would use Kevlar around the wheel openings and the attachment points. A set of Robart struts would be nice also (hint hint).
I should have it assembled this weekend, there is very little to do. The fuel tank already is plumbed and installed with fuel lines attached!
Brian Shipp
