RCU Forums - View Single Post - Its Here!! Double Vision
Old 03-29-2004 | 11:25 PM
  #116
JackL's Avatar
JackL
My Feedback: (7)
Default RE: Its Here!! Double Vision
Has anyone else had a problem with the placement of the triangular hardwood "pads" that the Aileron horns mount to? At least on my example, they are located almost directly behind the servo well. This does not allow you to offset the horn enough to the side of the servo in order to get a good 90deg. setup of the pushrod when the servo is at neutral. This is using only 1" servo arms. In order to get the proper geometry, only one of the screws in the horn is in hardwood, the other 2 are in balsa. Any ideas?
Jack
