RE: Lanier Ripper, didn't like the first day of spring.
Thanks for all the responses...
today i individually checked all the servo's on the plane, everything seemed to check out fine. I also tested the battery and the connection see if they were any loose connections. I did see if i wiggled the wire right below the connector it did glitch a little. That could of caused it, if there was enough viberation. So i rather be safe then sorry and used another battery i had laying around that was just built.
I need to run to the hobbyshop to get some more props since they were all broken.. Speaking of!! I never set the thottle cut on this plane but, would it help save the prop on landings by cutting the throttle right before touch-down? If so how do you set it up? I tryed playing around with it but, never seemed to get it to work.
