RE: GSP...PROS & CONS
The newer ARF designs are excellent but the hardware as most manufactures is garbage, other than that the F/g work is excellent and they switched to built-up wings instead of foam and balsa, nothing wrong with foam but you can really save weight if you have it built up.
