RE: Lanier Ripper, didn't like the first day of spring.
468hotrod- My radio is the model right before your 9cap, I have the 8UA. I can set the precentages on the radio but when i flip the switch nothing happens. Should I adjust the trim of the throttle to where i want to run without the swtich on, then when i flip the switch it will close? Ill look at it a little more see if i can figure it out. I want to get to the field again and see if i fixed the problem of the plane not flying.
Ill keep in touch...
