RCU Forums - View Single Post - modifying a blast!
Old 03-31-2004 | 05:35 AM
pompebled
Default RE: modifying a blast!
Hi, Rockyrunner,
What you could do:
- Replace the steering prop with a "normal" propshaft and rudder ( the coupling costs power and wears out rather quickly with a hotter motor)Use Graupner K-series props from 33mm upwards (see what you get away with speedwise before the motor starts to smell funny)
- Use one cell more, the ESC should be able to handle that, watercool the ESC and certainly the motor if in doubt.
- Replace the motor with a 9,6V version and run it on 12 cells (here you must certainly replace the steering prop, or be prepared to swim a lot, every time it sheds its parts...)
Feel free to ask, if there is anything that's not clear.
Greetings, Jan.
