Go Back  RCU Forums > RC Boats > Speed - Electric
 modifying a blast! >
modifying a blast!
Speed - Electric For all your electric boating needs.
modifying a blast!
Old 03-30-2004 | 08:31 PM
Default modifying a blast!
i have a traxxas blast that i wish to modify. i got this boat knowing that it was not the fastest, but i only wanted to have one motor and battery to deal with not 2 like the villan. i have lots of room to run the boat so that is not an issue. i want to make it baically as fast as possible. what should i do. i have 4 - 6 cell batteries, that are all brand new, so is it worth it to go up to 7 cell batteries? will the added weight reverse the benefits of the power? the speed control in it can handle 7cells i think. no to the motor. what is the best motor i can get, without completely redoing the inside of the boat to make rook for a bigger motor? thanks
Old 03-31-2004 | 05:35 AM
Default RE: modifying a blast!
Hi, Rockyrunner,
What you could do:
- Replace the steering prop with a "normal" propshaft and rudder ( the coupling costs power and wears out rather quickly with a hotter motor)Use Graupner K-series props from 33mm upwards (see what you get away with speedwise before the motor starts to smell funny)
- Use one cell more, the ESC should be able to handle that, watercool the ESC and certainly the motor if in doubt.
- Replace the motor with a 9,6V version and run it on 12 cells (here you must certainly replace the steering prop, or be prepared to swim a lot, every time it sheds its parts...)
Feel free to ask, if there is anything that's not clear.
Greetings, Jan.
Old 04-12-2004 | 11:03 AM
Intermission's Avatar
Take a look at this site. [link=http://www.marinerc.com/fastelectrics/blast/blast_modifications.htm]here[/link]
There is some good information about modding the blast.
Old 05-10-2004 | 02:07 PM
Banned
i have one all you need is a monster stock motor and seven cell batts the esc will handle it also put the trim all the way up on the rear out drive i did that to myne and now it is a lot faster
about 25 and a nice big rooster tail
Old 05-13-2004 | 10:18 PM
shenlonco's Avatar
[X(] My blast is set up the same as yours with a 6 cell pack and my stock tower hobbies turbo v II beats it and it's smooth and makes no noise at all 100% better than the blast!!
Look at the vid all the noise is from the crappy blast!
[link=http://www.arxreptiles.com/Other/104_0430.avi]BOATS RACING[/link]
