RE: how do you replace GWS gearbox shaft?
I remove the c-clip, and the gear. The shaft and the two ball bearings are still in the housing.
Do you pull the shaft through the front and push the shaft through the back?
The bearings do not want to come off the shaft. With the bearings on the shaft it is not coming out of the housing.
