RE: Lanier Ripper, didn't like the first day of spring.
Hey Rcfury,
Make sure when you are on the throttle-cut screen that the "switch" is set to the appropriate switch you want to assign it to. I know you can assign any switch to any function on my 9CAP, I don't know if you can do that on the 8UA. The second thing you have to set is the UP/DOWN/NULL position for that switch. You want the throttle to be set with your throttle trim to the the normal idle level. When you pull up on the spring-loaded switch you want the throttle to close the rest of the way. In this example, you would set the switch for the "UP" position meaning that the throttle cut is activated when the switch is in the "UP" position. I hope this is clear.
Ray
