RE: Cap 232?????
they are grayt flying planes until you try to do anything 3d with them. see, in real life, you can not pull enough up hard enough to snap out of a vertical pull in a real plane without killing yourself, so that does not matter. but when you take the design and scale it down then you are pulling more g forces than you could if you were in the plane and artifacts like that show up in the performance.
