RE: Jetcat V2.00 ECU
All of the above comments are excellent, but I would suggest you do a good range check to be sure. Get a baseline distance with the ECU unplugged, then do a range check with the turbine running ultimately at full power. If you measure 20% or less reduction in baseline distance your OK. Any more than a 20% range reduction is an indication your RF link is getting pounded.....
Lee H. DeMary
AMA 36099
