RCU Forums - View Single Post - Quick building question
Old 04-01-2004 | 10:03 AM
fhm101's Avatar
fhm101
Default RE: Quick building question
When you stack your brake parts on their studs, put a shock seal O ring between the friction pads. You can also get little springs from OFNA for the same thing, or make your own from a ball point spring. The O ring or springs will keep the pads pushed apart so they won't drag on your brake rotors when you are not using them.
