RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Quick building question
Old 03-31-2004 | 09:26 PM
Default Quick building question
I'm building my mugen mbx5 kit. It says to use "rubber" glue to glue the brake pads to their matching metal parts. What the heck is rubber glue? What kind of glue have you guys used for this?
Old 04-01-2004 | 02:56 AM
Default RE: Quick building question
Anyone?...
Anyone?...
Bueller?
Old 04-01-2004 | 07:34 AM
rubber cement.... you can get it from you local hobby store, or a craft store... like Micheals.
Old 04-01-2004 | 09:20 AM
fhm101's Avatar
Don't glue the pads to the backing, let it all float and use shock O rings between the to keep them from dragging on the rotor when they are released.
Old 04-01-2004 | 09:25 AM
i was wondering. That is how it is on my PCR. Thought it was wierd that Mugen would use glue. What is this you say about the o-rings Fhm? where do they go? i did not know of this. A picture may help me.
Old 04-01-2004 | 10:03 AM
fhm101's Avatar
When you stack your brake parts on their studs, put a shock seal O ring between the friction pads. You can also get little springs from OFNA for the same thing, or make your own from a ball point spring. The O ring or springs will keep the pads pushed apart so they won't drag on your brake rotors when you are not using them.
Old 04-01-2004 | 10:05 AM
awesome. Thanks bro... i learn something to better myself or my buggy every day.
Old 04-01-2004 | 10:35 AM
I would be hesitant about not glueing them, might they have a chance of getting torn off?
Old 04-01-2004 | 10:49 AM
i have no problem with mine. I know there is probably different methods, but i know mine is okay. I am going to use the o-ring tip though.
