RCU Forums - View Single Post - Correct Rx length
Old 04-03-2004 | 12:08 AM
NMPhi767's Avatar
NMPhi767
Default RE: Correct Rx length
Those darn parkflyer antennas! They look pretty funny sticking out of your plane. Unfortunately they are very necessary! NEVER cut them or your range will be reduced severely! Their are three options I can think of. There are some antenna bobbins that you can attach to the plane. You wrap the antenna around this and supposedly it does not reduce the range. Second, I have seen other pilots solder on the short aftermarket antennas to their recievers. These still have about 10 to 25 percent less range though. Third, you can do what I do, just let it lag behind or in my E-Starter, I ran it from the leading edge of the wing(sort of where you bolt the wing on) and used small pieces of tape to "hang" it the the edge of the vertical stabilizer. I then ran it down the edge of the rudder and back up the fuselage towards the nose of the plane.
