bonified, Let me know if you need help with anything on your truck when you get it. Also, check your gear mesh when you get it, there have been some trucks that have been shipped with incorrect gear mesh. I have a post on here with a good way to check and set the mesh. Also, you can get parts from
www.ehobbies.com and
www.toyhaus.com. ehobbies is cheaper, but toyhaus ships faster. You will want to pick up an extra set or two of diff cups, an extra set of spur gears, glow plugs, and some axle pins. These are the most commonly damaged things on the MT2, so they are the most important to have on hand.
