Transmitter throttle problems !!!
I have a Futaba Skysport T4YBF transmitter that came with the Nexstar Select RTF.
Last night I was in the basement while setting up control throws on another plane the Throttle/Rudder Stick stopped
working. The throttle stick seems to spring back when pushed past the half way point. It has a lot of
tension on it when pushed past this point (half way point). Also when throttle stick is all the way back
it tends to wobble a bit.
Is this a problem I can fix or will I have to send it back to Futaba?
Omaha_RC_Flyer
