RCU Forums - View Single Post - Qustions on CG Eagle 2
Old 04-03-2004 | 05:43 PM
czechyour6's Avatar
czechyour6
Default RE: Qustions on CG Eagle 2
I built the Eagle 2 kit and it is a great trainer. I did do the bolt on wing modification so there are no rubber bands to monkey with, a nice clean look. I think Dubro makes the nylon bolt kit. If I could do it again, I would mount a servo in each side of the wing with direct servo to aileron connection and put a little larger aileron stock or glue a triangle piece on the front to make it a little longer. Sure its a trainer and you can set it mild to learn, but after that, you want it to roll good. It takes forever and you will run out of altitude waiting for it to come around. as long as you have enough elevator travel, it will even fly inverted WOO HOO!
