RCU Forums - View Single Post - GP Cessna, maiden flight
Old 04-04-2004 | 10:06 AM
GarySS
My Feedback: (13)
Default RE: GP Cessna, maiden flight
HILL202 and Crashland and any other GP Cessna fliers,
I am close to mounting my OS.52 in this plane. How have you mounted your engines? Are the cylinder heads exposed? How is the cooling during a hard engine run? How much have you opened up the bottom for cooling? Do you think if I mounted mine so there is NO cylinder hole would I have cooling problems? I have opened up two air intakes aside the spinner and will also probably add a smallish opening in the front........IF I open up some air exhaust holes in the bottom should I be OK.
Thanks for any responses.
